JD 246 marker disc assembly
Stephen in SOK
03-14-2006 18:23:08
Anyone have a marker disc assembly they'd like to sell or know where I can find one? JD no longer carries, having no luck on fence row searches and planting time is right around the corner. Thanks
jason(ma)
03-15-2006 20:28:17
 Re: JD 246 marker disc assembly in reply to Stephen in SOKY, 03-14-2006 18:23:08
I use 36" spacing and set the tractor wheels for row markers on my 290, 6 ft on center. just drive right back over the old wheel track. 30" row would be on the narrow side for me to do this with my tractor.
John e.c.MI
03-15-2006 17:16:24
I probably have a few that I would let go pretty cheap. Let me know and I can send you a picture to make sure we are talking about the same thing.
Carl Glass
03-15-2006 11:27:28
Yes I have a disk marker assy. e-mail me if you still need one and maybe we can make a deal.
Carl
Leroy
03-15-2006 05:12:00
Even a cultivator shovel bolted on will work, that is what Dad used as he didn't like the rolling disc, and supprised that JD no longer carries as that same marker used up thru the 1200 series
Stephen in SOKY
03-15-2006 06:09:51
 Re: JD 246 marker disc assembly in reply to Leroy, 03-15-2006 05:12:00
I found it hard to believe as well. Local JD parts man showed me an assembly for the 7000 series which would not adapt for my use. Said that was all he could get. I was scared of the price rather than availabilty only to find the opposite to be the issue.
ricedaddy
03-14-2006 19:05:02
are you talking just the disc with stud and bearing? If so what size, I may have one of of a set of Bearnitine marker!
[email protected]
ricedaddy
03-14-2006 19:04:48
[email protected]
