loader pump
Dave in Auberry
03-14-2006 17:13:35
can any one tell me what pump is used for the Ford N tractors that is attched to the crank and works the loader. Does it mount to tractor or the loader frame?
lonestarjeff
03-22-2006 20:32:41
 Re: loader pump in reply to Dave in Auberry, 03-14-2006 17:13:35
Dave:
The later Ford loaders(700-series)that can be found on the N's use a front bracket between the loader & tractor, the pump mounts to the bracket.
The manuals for these loaders always show a Vickers vane pump in the kit, but other brands w/ the same SAE flange & shaft will work.
Jeff
Ross
03-15-2006 20:23:50
I've got a Cessna pump on my oliver w/Duall loader looks just like the one my friend has on his 850 Ford with wagner? loader. They both bolt to the front loader supports.
Dave in Auberry
03-14-2006 18:36:13
 Re: loader pump / THANKS GUYS in reply to Dave in Auberry, 03-14-2006 17:13:35
Thanks Guys
old
03-14-2006 18:03:37
Coomn pump is a vicker vane pump. Both my 841 and 8N have one on them. They mount to the loader frame, put out around 8GPM at around 2500PSI
Roy Suomi
03-14-2006 17:47:05
Pump is attached to the loader. Not sure what brand or size it is..
