Horse Trailer vs CattleTrailer
Phil/PA
03-13-2006 13:41:57
Is there a difference between a horse trailer and a cattle trailer? The reason I"m asking is because a friend is getting ready to sell their two horse trailer but I need one for cows and the question came up as to whether two cows would fit in a two horse trailer. For the main purpose of hauling cows would there be any reason not to get a horse trailer other than the price difference? The question came up as to whether cows were wider and if two would fit in a two horse trailer. I don"t know anything about horses and he didn"t know anything about cows.
souNdguy
03-14-2006 06:21:46
 Re: Horse Trailer vs CattleTrailer in reply to Phil/PA, 03-13-2006 13:41:57
If you are loading cows.. you may wand a stock trailer. A stock trailer can usually handle horses ( by using a divider ).. or the divider can be removed and load cattle/livestock.
Both types of trailer.. horse and stock have escape doors usually.. the big difference you see between horse only, and stock, is the horse trailer will have a lowered door/ramp.. or a big swinging door.. where A STOCK TRAILER MAY HAVE THE SWINGING DOOR, AND A CHUTE SLIDE INT HAT DOOR.. THAT WAY YOU CAN BACK UP TO A CATTLY CHUTE, AND JUST SLIDE THE CHUTE DOOR OPEN.. RUN THE CALVES IN, THEN SLIDE SHUT.. WITHOUT HAVING THE WHOLE BACK OF THE TRAILER OPEN AS A HORSE TRAILER, door open. ( oops.. caps lock clicked on.. )sorry..
Soundguy
Tom in TN
03-13-2006 18:34:46
Phil,
I have a two-horse trailer and do not have a stock trailer. I haul two calves (500 - 550lbs. each) in my trailer with no problem. I can haul one adult cow (1200 - 1300 lbs.), but I would not try to put two adult cows in the trailer. Two horses will stand still, side-by-side and ride nicely. Unfortunately, you can't restrain the cows when they're in the trailer, and they get really rowdy.
Also, I had to rig up a chain-and-board deal to close the gap between the top of the tail-gate and the top of the trailer so that the calves can't "jump" out of the trailer when they're in it.
I would love to have a stock trailer, and I plan to buy one someday - when I win the lottery.
Good luck,
Tom in TN
Charlie M
03-13-2006 16:56:59
I've trucked a single cow in a horse trailer with no problem. Needs to be a trailer where the divider in the middle can be removed.
Allan In NE
03-13-2006 13:51:13
Phil,
You need a stock trailer instead of a horse trailer.
The nags can always ride in a stock trailer, but horse trailers are kinda built around the use of the ponies and don"t leave a lot of room
Allan
