would like a disk for an 8N
Dave H. (CO)
03-13-2006 11:14:48
I"m looking for a disk for a 8N to use in sandy soil. How big is too big, what do I look for in a used one to see if it"s good? (Cracked discs, missing scrapers, sloppy bearings, etc.)
Thanks in advance.
pappy in Mo.
03-15-2006 10:40:33
 Re: would like a disk for an 8N in reply to Dave H. (CO), 03-13-2006 11:14:48
I pull a 6 ft Ford 601J with good results. Would not go much heavier.
souNdguy
03-13-2006 12:19:45
You should be able to pull a 5-6' dual ganged disc. i like the box frame units as they are heavier and sturdier.. your choice on the grey iron greasable bearings, or the sealed bearings... Your N will pick up about 750-800# of weight on the rear befor ethe front end comes up.. hang some weight on your bumper to help with that. in any case.. 900-1000# will make the relief valve unseat, assuming your lift and pump are up to snuff..
I pulled a dual ganged 5.5' old ford disc with my 8n fine.. was all that it wanted to lift too..
Soundguy
Dave H. (CO)
03-14-2006 06:30:35
 Re: would like a disk for an 8N in reply to souNdguy, 03-13-2006 12:19:45
Soundguy,
Thanks! The lift works pretty well, so that shouldn"t be a problem.
David
