71flexplanter questions
mikeinWA
03-13-2006 09:47:38
About a year ago I posted a bunch about seeder choices for my market farm. We grow alot of varieties of alot of different crops in relatively small quantities. Long story short I ended up with a gang of three Planet Jrs, and threw in a two row JD71 for use on large seed: corn, peas and beans. I have the operators manual and the simple excersise of setting up for peas gets a little more complicated with every page I read. There are different hopper bottoms for different seed etc. My question is this. If there is anyone out there using these seeders for more than a single crop, how do you determine seed plate choice for peas/beans? (typically because of nature of my business these are not included with seeds) do I need different bottoms for these seeds? What ever happened to Riverbend? Is he still posting?
Thanks for the help.
Mike Peroni
riverbend
03-13-2006 16:17:27
 Re: 71flexplanter questions in reply to mikeinWA, 03-13-2006 09:47:38
Hi Mike,
I have been busy getting my greenhouse ready, washing and filling flats, seeding onions, etc. Onions are emerging, eggplant is getting seeded this week. Just in time for the lows to drop back into the low teens at night.
For the larger seeds, I am using corn / bean hoppers. To get the seeding rate, start with a plate that is thick enough to contain the seed (soybean plates will work for most peas and beans). The press wheel is 4' in circumference (I think). Put some seed in the hopper and turn the wheel twice around. Put a cake pan under the shoe and turn the wheel one turn. Count the seeds / 4 = seeds per foot. Adjust the sprockets to get the rate right.
Every variety of bean seed seems to be a different size, so this year I bought a selection of seed plates (Lincoln Ag corn plates) because changing plates is easier than changing the sprockets every 4 rows.
I have a second gang of four planters with sugar beet hoppers that I use for arugula, mizuna, radishes, all the small seeded stuff. I think that you could add a filler plate to the corn / bean hopper and get nearly the same result.
Kind of early to be working on planters isn't it ? You can't thinking about planting, are you ?
Greg
mikeinWA
03-13-2006 19:34:16
 Re: 71flexplanter questions in reply to riverbend, 03-13-2006 16:17:27
Man am I glad to hear from you.Just got in and havent let the details of your post soak in, but yeah, I usually get to sneak in a planting of early peas and roots, along with quick greens, in mid March. The weather is definitely not cooperating this year, but after the first of April around here its all in. I will definitely rattle your cage with some more question tommorrow. I hear you on the greenhouse work. We still sub contract to the local college to grow our starts at 7.50-10.00/flat. It's starting to make sense to do them in house but I hate the idea of giving up my "vacation".
Mike Peroni
ricedaddy
03-13-2006 09:57:42
Mike, the bottoms your talking about are called plates, your friendly JD dearler should be able to print you a list of plates for that planter
good luck
Ron
mikeinWA
03-13-2006 10:42:29
 Re: 71flexplanter questions in reply to ricedaddy, 03-13-2006 09:57:42
According to the manual there are different hopper bottoms, at least for corn, sugar beets, peanuts/edible beans, and some low rate choices. There are also different wheels, star wheels etc. Its possible I am making this a bit more complicated than it has to be, but this will be my first time using this type of seeder and I would like to level out the learning curve as much as possible. Most local growers are using much newer seeders, those that do remember the 71s used them exclusively for sweet corn and always got their plates with the seed.
Thanks
