John Deere #37 Sickle Mower Remote Hydraulic Cyl.
MarkieJB
03-09-2006 19:07:20
Can anyone please direct me to where I can purchase the remote hydraulic cylinder, which was an option, for a John Deere #37 pull behind sickle mower? I'd like to take advantage of this option but the previous owner lost the cylinder. Thanks!
Dave H (MI)
03-10-2006 11:50:18
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to MarkieJB, 03-09-2006 19:07:20
I'm with Bob. Go to TSC and buy the stock 8" cylinder. It is a red so ugly even a Farmall guy would repaint it so get yourself a can of nasty green paint too. Works fine on my JD#5 mowers.
MarkieJB
03-10-2006 13:03:57
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to Dave H (MI), 03-10-2006 11:50:18
Thanks Dave H. I'm going there after work to get one.
Bob
03-09-2006 22:13:04
Isn't it just a common 8" stroke remote cylinder?
Likely, a 2.5", 3", or 3.5" bore, depending upon how fast you want it to lift.
MarkieJB
03-10-2006 06:57:35
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to Bob, 03-09-2006 22:13:04
Thanks for the quick responses. I had no idea what to even start looking for. I knew there"d be someone on here who would know. Thanks Again!
Leroy
03-10-2006 05:37:49
Or possibly a 2", faster but may not work with a 800# or less hydrolic system on tractor, some Farmall's had only a 450# PSI system
MarkieJB
03-10-2006 07:05:30
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to Leroy, 03-10-2006 05:37:49
I'll be using this mower on either a 45' Farmall M or a 59' Farmall 560 - most likely on the 560 but the mower "came with" the M. What bore cylinder would you suggest? Thanks Very Much!
Leroy
03-11-2006 10:11:34
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to MarkieJB, 03-10-2006 07:05:30
I would say go with the 3" as most companys do not make cylinders in 1/2" sizes and 3" would give you enough lift to use on any other piece of equipment you may have now or in future with either tractor unless on the M you have that verry low pressure setup and then that 3" should handle the mower or plow but probably not a heavy wheel disc altho on your big tractor it would handle a disc, if the M has the higher pressure setup then it would be the same pressure as the 560
MarkieJB
03-11-2006 18:15:07
 Re: John Deere #37 Sickle Mower Remote Hydraulic C in reply to Leroy, 03-11-2006 10:11:34
Thank You Very Much for all the information and suggestions!!!
