Question for HAY DOCTOR
Hay Fever
03-09-2006 10:56:22
HAY DOCTOR do you have a dimension for the Vicon Blade that fits the Lely Optimo 205 and where do you get these blades?
Hay DR
03-10-2006 05:57:06
 Re: Question for HAY DOCTOR in reply to Hay Fever, 03-09-2006 10:56:22
third party image
The Vicon 58699 & 58700 has a 18.5mm hole, the blade is 4mm thick, 120mm long and 48mm wide.
These blades are available at most hay equipment dealerships. The price may vary but we sell the quality blades at CCM for $1.60 each.
Hay Fever
03-10-2006 10:29:18
 Re: Question for HAY DOCTOR in reply to Hay DR, 03-10-2006 05:57:06
That explains my original problem. The old blades I got from LELY were the same dimensions as the VICON numbers you gave me. The new ones they have been sending with their part number stamped on them are 2 inches wide instead of 1and 7/8"s. Wierd huh? Are there any weak points in this LELY mower that you know and I should be on the lookout for? And how do I get ahold of CCH? Thanks for the info!!
