Bush Hog Sq720 vs. Land Pride RCR1872 vs Woods
jmauss
03-08-2006 19:38:09
I appreciate the replys to my earlier post about tail wheels and slip clutches. I have decided to go with both the slip clutch and the laminated tail wheel. Now I am narrowing down brands. I'd like to go with a medium duty unit, but I only have 4 acres to keep clear, so I am going to go with the light duty model.
I am considering the Bush Hog SQ720, the Land Pride RCR1872, and the Woods Brush Bull 72. Do any of you have any experience with any of these? Is one better than the other, or are they so comparable that it becomes a matter of personal preference. If they are nearly equal, I will be going with the Bush Hog since it is the least expensive of the three and since it is red and will match my tractor.
Your opinions are appreciated.
Joe
Mark in Central VA
03-10-2006 11:08:49
 Re: Bush Hog Sq720 vs. Land Pride RCR1872 vs Woods in reply to jmauss, 03-08-2006 19:38:09
I bought a new Bush Hog SQ720, 6 ft cut, in 1998. This is a nice machine, I've had no problems with it cutting 25 acres of brushy land each year. I have the slip clutch and a stump jumper (disk on the bottom to jump over, rather than catch on stumps etc.) on it . I just lube it each season before use and it has worked great.
I pull it with a 52 pto HP IH 574 diesel tractor which is probably about as light as you'd want to go with this particular cutter. Running the PTO at high RPMs for 4 or 5 hours at a time when operating a brush cutter can be hard on a tractor. Be careful to match the machine to the tractor, else you risk wearing out the tractor prematurely.
Cutting brush and fields is dusty, dirty work. The tractor's radiator and grill will fill up with leaves, straw, dirt, etc after a day or two of running the brush cutter. It's important to keep this clean. I remove the grill, clean the big stuff out by hand, and use a compressed air sprayer to clean the radiator fins. Don't use water for cleaning, it can clog the fins. When I keep up with the cleaning, I have no tractor over-heating problems. Again, due to the dusty conditions, remember to change the air breather and other filters, and oil regularly.
Regarding the other brands, I have no experience with them.
farmallhal
03-09-2006 19:21:22
I have a SQ720 which I purhased new a few years back. I use (actually the wife uses it the most) it to keep about 7 acres cut back around the house place along with fence rows in several places on the farm. I have the slip-clutch and laminated wheel options as well. Have never had a problem of any type with the unit. Mine is a 3 point model and is behind a Ford 3610 and used in all types of grass. We have two other Bush Hog models of different sizes and have been very satisfied with their performance. Hope this helps. Hal
Lou
03-09-2006 11:21:56
Last yr one of the castings that holds a universal joint broke on my 720, never had that happen on the 5 ft JD that we beat up for years. Hard to say which is better.
MadMallard.....NY
03-09-2006 06:20:46
I have a Bush Hog 7' Squealer that I bought new over 10 years ago. I cut around 150 acres a year with it. So far the only thing I've replaced is the blades (one set). It's a very good machine and I highly recommend it.
Jim from WV
03-08-2006 21:07:27
Bought the 7' Woods Brush Bull 84 new in Fall of 2005. That is their widest light duty model. It was cutting brush beyond its' rated capacity. I was hitting cinder blocks, fence posts, boulders, tin roofing and everything else 100 years of bad farming left in the fields. It performed great. I did catch and bend a removable shield on debris that should have been designed with bolts closer to the end of the guard, but we are talking cosmetics here. I am very happy with it. The BB84 is 1000 pounds so I have to keep my bucket on to avoid doing wheelies. The BB72 is 702 pounds if that is a factor for you? Good luck. Jim
