bs splitter stalls
bcPA
03-08-2006 18:56:56
my 5 hp b&s powered wood splitter which was bought at sears about 28 years ago has started to act up. Last summer when it was hot outside it would work ok till it warmed up then it would stall at the slightesrt strain. I started it last week and it ran till it ran out of gas.Now that it is cool out I tried using it and it works good once it is wormed up but after about a half hour it wants to stall when it should not. Where should I look for a problem?
Angle Iron
03-09-2006 03:13:42
 Re: bs splitter stalls in reply to bcPA, 03-08-2006 18:56:56
You may want to check the clearance on the exhaust valve. I have had this hot no start or hard start problem and setting the valve clearance has done the trick for most of them. The stem streaches over time and doesn"t let the valve seat all the way when hot.
