JD 2240 draft control
Stephen in SOK
03-07-2006 18:09:06
Can't find my manual, can anyone tell me which notch the lever under the seat should be in to activate automatic draft control when plowing? Thanks very much.
ET
03-09-2006 04:52:39
 Re: JD 2240 draft control in reply to Stephen in SOKY, 03-07-2006 18:09:06
Use the LD position. The L position gives load control. It raises and lowers the impement for a steady rate of pull. The D position gives depth control. The impement stays a a set depth or hight regardless of the ups and downs of the terrain. The LD position gives depth control but still gives some correction as draft loads change. This gives some weight transfer for better traction.
Stephen in SOKY
03-09-2006 06:57:10
 Re: JD 2240 draft control in reply to ET, 03-09-2006 04:52:39
Thanks for the help!
