Removing floor drag chain on spreader
Jeff Jackson
03-06-2006 10:22:37
I have a New Idea 12A manure spreader that needs the floor boards replaced. Is there a way to seperate the drag chain links without damaging them in order to make it easier to replace the flooring? I"ve been told you can replace the boards without removing the chain but it seems it would be much easier if the chain was out of the way, especially since I"m doing this myself without any "extra" hands. Thanks
JMS/MN
03-07-2006 12:15:14
 Re: Removing floor drag chain on spreader in reply to Jeff Jackson, 03-06-2006 10:22:37
Like broomstacker says- the tool is a flat chain detacher- made of cast iron- should be in any farm store. Otherwise, use a chisel to punch it apart, with a thick flat iron behind the chain, against the spreader box.
Bill WI
03-06-2006 14:50:11
Does this bring back memories. Yup That's the way and if you broke one side that's the way you get a new one in after you fork the load off by hand. This happens much more when it's -10 and a good wind. lol
Jimmy King
03-07-2006 03:09:29
 Re: Removing floor drag chain on spreader in reply to Bill WI , 03-06-2006 14:50:11
O'h yea been there and done that.
Jimmy King
03-06-2006 10:33:24
Loosen the chain up as much as possible, the front sprokets should slide back to do this. Then kink the chain so the slot on the underneth side lines up with the next link, and drive it out. You will need to have something to buck it with, as you drive it out.
Broomstacker
03-06-2006 17:05:56
 Re: Removing floor drag chain on spreader in reply to Jimmy King, 03-06-2006 10:33:24
We used to have a hand tool that had 4 or 5 different sized slots in it to grip and back up flat chain links to do just what you're saying. I would think flat link chain manufacturers would still sell such an item??
