Corsicana Shredder
Harv
03-02-2006 08:46:58
The tail wheel on my Corsicana Model A does not pivot around when backing - it catches on the deck of the shredder?! Does a lot of plowing in this mode and tears up the yoke. The wheel on it is, I believe, about 17" in diameter (?).
Should I be using a smaller diameter tail wheel? I think the 1.5" shaft may be a bit loose in its carrier, and if in tight, might pivot 360 degrees, but can't figure out how to shim it.
DIRTYDAN
06-07-2007 10:29:46
 Re: Corsicana Shredder in reply to Harv, 03-02-2006 08:46:58
I had that problem, but the inside of the wheel hub was worn causing it to "wabble" around.
I cut some pipe and inserted it to tighten it a bit.
