is it possible to make a hay tedder??
tugboattim
02-24-2006 05:55:58
wife only spends money on toys she wants. I have plenty of metal and welding skills anybody know of and plans out there thanx as always tim
RickL
02-26-2006 03:52:46
 Re: is it possible to make a hay tedder?? in reply to tugboattim, 02-24-2006 05:55:58
why. I have assemble some of those and used one once just to see what all the hype was. Wouldn't want it if gave to me. If my hay gets to stage from rain when itneeds tedded I just use batwing mower.
msb
02-24-2006 20:17:28
Adapt a hydraulic motor to about any rake except a wheel rake of course.Run it forwards,backwards or at any reel speed you want.Fluff up a windrow or very gently twist one up or even tedd hay with it.
Hugh MacKay
02-24-2006 15:28:41
Tim: The answer is quite simple, get the wife a pitch fork.
Quebec Red
02-24-2006 18:04:43
 Re: is it possible to make a hay tedder?? in reply to Hugh MacKay, 02-24-2006 15:28:41
Now Mr. Hugh: remember now that you are retired from trucking and are not palleting trucks, is this your new suggestion to keep weight off? I must be careful as my wife sure as heck can outrun me!! ( do not ask how I think I know)....QR....
Hugh MacKay
02-24-2006 18:26:54
 Re: is it possible to make a hay tedder?? in reply to Quebec Red, 02-24-2006 18:04:43
Red: No, I clearly thought that if the Mrs. wouldn't allow Tim to spend the money for a hay tedder, a few hours shaking out hay with a fork, may change her mind. I know it would work if I were passed the fork.
Quebec Red
02-25-2006 10:37:28
 Re: is it possible to make a hay tedder?? in reply to Hugh MacKay, 02-24-2006 18:26:54
Okay Mr. Hugh. Point taken and duly noted. Will add this negociation tatic to my list. If I get expelled from Quebec, ( by SHE who must (should) be obeyed) maybe I can build one of those modern doghouses that was discussed on , I think Tales a while back in the lee of your Farmall shed????? ????? ??!!!!...QR..
JD9295
02-24-2006 14:48:22
Buy an old hay rake and reverse the drive, thats the cheapest tedder youll find
mjbrown
02-24-2006 10:42:47
There are quite a few gearboxes on a hay tedder and the tines are spring steel. Then there are hubs wheels and tires. After that it's mostly cutting and welding.
peteL
02-24-2006 07:54:00
The Grimm Super 8 tedders look like someone assembled them in their garage.
