IH RUNNING GEAR
ryan from WI
02-22-2006 14:34:24
Do any you poeple know of a ih running gear that had a dump bed with hydurliac dump or a ih runnning gear that was populaor.
Dean in iowa
02-25-2006 16:54:26
 Re: IH RUNNING GEAR in reply to ryan from WI , 02-22-2006 14:34:24
If your interested in an IH gear with a IH flair box, contact me. Also have a hoist for it.
1031D
02-22-2006 21:22:09
There is a guy west of me that has one. It has the 1960's McCormick decal on the side, it's around 12-16" tall on the sides. It is mounted on an IH gear with the strait retangle type side frames instead of one round center reach. The hoist under it also says IH on it, with the same single acting cylinder my cyclo planter uses.
matthies
02-22-2006 19:28:48
There's a guy in town that has a dumpbody that you mentioned on a gear. It has 12-16 inch sides and has IH or McCormick on the dump, can't say if its on an IH gear or not. But the bed is really wide and long compared to most wagons. chris
J.C.H.
02-22-2006 18:37:24
In the 1960's when I Farmed in LaSalle Cty. Ill. I had two Dump boxes on Case 8 ton gears Mfg by Kennedy Truck Equip. with High Pressure Cyls for use with AC Tractors. They were sized much the same as would be put on a one ton Truck Chassis. they had Steel Frames, Sides and the Floors were Steel Diamond Plate.1/8 " thick Material.
