Carb Icing
Mark Ollila
02-20-2006 15:13:00
Go to "Gallaries - Tractor Photos" for pictures of my carb icing fix. This is a solution that works for me on my 1953 Super H. I "guessed" correctly for the size. Not too much heat (with a loss of power and detonation) and not too little heat (icing continues). HTH.
Mark
Jerry/MT
02-20-2006 18:40:47
 Re: Carb Icing in reply to Mark Ollila, 02-20-2006 15:13:00
Pretty slick, Mark. If you got one of those old muffler cut out valves like J C Whitney sells you could manually control the heat, closing the cut off to warm the air and opening the cut off to bring in cold outside air.
Mark Ollila
02-21-2006 21:27:10
 Re: Carb Icing in reply to Jerry/MT, 02-20-2006 18:40:47
Jerry,
Good idea. It would make the engine perform better in a wider temperature/humidity range. As it is, I take this heat system off in warmer weather and use the production cap. Farmalls (at least the H's and M I own) still get icing in the summer when the humidity is high enough.
Mark
jossette
02-20-2006 16:53:10
 Re: Carb Icing pic in reply to Mark Ollila, 02-20-2006 15:13:00
third party image
cool
