JD 7300 vac planter
mekfarner
02-19-2006 19:32:25
What advantages to upgrade to a 7300 JD vacuum planter over a 7100 JD plate planter? Also would it be possible to use corn shelled from previous season to plant the following year. I have done this with wheat and oat seed without problems
ricedaddy
02-21-2006 18:25:38
 Re: JD 7300 vac planter in reply to mekfarner, 02-19-2006 19:32:25
Link
ricedaddy
02-21-2006 15:53:39
there's no comparison between the 7100 and the 7300. The 7300 will outplant the old 7100 any day of the week. Also will space the seed much better!
Do you have the V press wheels on the 7100, if so that's another-
jms/mn
02-20-2006 08:26:32
'Brown-bagging' works on small grains and soybeans, but with corn hybrids it will produce very little grain. There is corn whose seed can be used, I think it's called 'open pollinated'. It doesn't yield much to start with, but is cheap. Economics support using hybrid seed.
