Stabilizer while plowing
WNC
02-16-2006 19:19:16
Is a stablizer used while plowing? If not could you explain. Where is a stabilizer used? I appreciate your imput. Thanks
cj3b_jeep
02-17-2006 13:04:54
 Re: Stabilizer while plowing in reply to WNC, 02-16-2006 19:19:16
I use mine with my brush hog to keep it from swaying on hills and turns, also with my back blade and boom. I've never plowed, but I sppreciate the info on not using it while plowing, I never would have thought you'd want it to move.
MikeinKy
02-16-2006 20:07:13
No. The plow should be able to sway side to side when plowing. Stabilizers better known as sway bars are used with planters, cultivators, or other tools that need to be inline with the tractor at all times.
sammy the RED
02-16-2006 19:49:24
I use a stabilizer in the gas for my 2-cycle equipment ?
