Hydraulic Cylinder Search
IL Dennis
02-12-2006 11:24:29
Without much luck, I"m looking for a telescoping hydraulic cylinder. I want to replace the manual angle adjustment on my rear blade to a cylinder. It needs to go from 12" closed to 20" open. Thought this would be an easy thing to find, but I guess I thought wrong. Where can I find one?
Bernie in MA
02-13-2006 16:48:59
 Re: Hydraulic Cylinder Search in reply to IL Dennis, 02-12-2006 11:24:29
baileynet.com has a lot of cylinders and will make them to order.
IaGary
02-12-2006 20:30:56
Don't think you can get one to do that.
Because that is a 8" stroke and a 8" Stroke cylinder is at least 16" long in it's retracted position.
Can you move one of the mounting holes farther apart by cut and weld.
I think that is the only way it will work.
Moving one hole will still give you 8" of travel and that is all that matters if it has enough side clearance.
Good luck.
IaGary
02-12-2006 20:35:02
 Re: Hydraulic Cylinder Search in reply to IaGary, 02-12-2006 20:30:56
After reading your post again maybe you are wanting a clinder that has a 2 stage ram. Ive never seen one of those in that size and if you do hang on to your wallet.
Good luck.
old
02-12-2006 11:49:48
You might try surplus center if you haven't already 800-488-3407
