Sorry, title got cut off, meant to ask:
K-stater
02-11-2006 16:55:59
What the difference is between a JD 7000 conservation and a JD 7000 Conventional corn planter.
paul
02-11-2006 19:07:51
 Re: Sorry, title got cut off, meant to ask: in reply to K-stater, 02-11-2006 16:55:59
I believe the frame tube is larger on your conservation as well. I imaging all the extra weight required the different lift, comparable to larger JDs.
My understanding is they were an early try, certainly not a no-till drill, but somewhere in between.
--->Paul
IaGary
02-12-2006 04:25:31
 Re: Sorry, title got cut off, meant to ask: in reply to paul, 02-11-2006 19:07:51
The conservation planter was set up to no till thus it had the colters and heavier. They went to the wheel cylinders because the rock shaft was aweak point with the extra weight of no till equipment.
The markers should be heavy enough.Around here guys didn't modify the markers for no till and they worked fine.You just spin or twist the disc on the end to make it more aggressive to leave a mark. If they are busted up on that one they must have hooked it on a tree or something. Yes the springs should be heavier also on the conservation and adjustable for the conditions.
Which coulters does it have? The coulters mounted to the row unit and not the frame work better in this area.
Hope this helps.
K-stater
02-12-2006 20:41:28
 Re: Sorry, title got cut off, meant to ask: in reply to IaGary, 02-12-2006 04:25:31
I believe the coulters are mounted on thier own frame in the front and have their own heavy springs.
IaGary
02-13-2006 05:24:04
 Re: Sorry, title got cut off, meant to ask: in reply to K-stater, 02-12-2006 20:41:28
Most guys didn't like those as well that were on the frame instead of unit because they did not follow the ground as well.
Over humps or valleys they were to deep or to shallow instead of the gauge wheels on the unit holding them up or letting them down.
Usually ahead farther and did not followw in line on contour or curved rows.
Just my thoughts.
