making a plow
Tim Shultz
02-09-2006 18:18:00
I am thinking about making a three/two bottom plow.. just wondering if anybody has plans? or a picture of a simple one.. three point is what I am looking at.. I know you guys might think I am nuts, but money is tight and I want to giver 'er a try.. thanks! Tim
sjh
02-11-2006 13:32:24
 Re: making a plow in reply to Tim Shultz, 02-09-2006 18:18:00
You could always get a trailer plow. They still work good. Around my area of NY unless it is a JD they go pretty cheap.
Hugh MacKay
02-10-2006 15:54:16
Tim: I'd think long and hard about that one. You will never do it for the price 3 bottom plows go for. You might cut a 4, 5 or 6 bottom down to 3. Make sure you get your engineering right.
If you talking fabrication of a plow frame forget it.
Jerry (AL)
02-10-2006 11:43:20
I heartily agree with the suggestion of cutting down a larger plow. Around here, they sit in droves all over in the 4-5 bottom variety. The larger ones can be had for scrap iron price in most cases where a 2-3 bottom plow will bring $300-350.
cj3b_jeep
02-10-2006 05:34:06
I'm going to a consignment auction in Wooster, Ohio this weekend and hoping to pick up a 2-3 bottom 14" three point plow for a decent price. Used equipment dealers seem to want 200-300 dollars for them.
I think you'd be far better off finding one rather than building. One all together is worth less than the sum of the parts.
old
02-09-2006 19:44:04
Well unless you have a good bit of real heavy iron around you will find that you will spend 2 or 3 time more money on one then finding one at and auction. I've been to auctions where one will go for $10 one time and the next time one will go for $500. One of those things where you need to be in the right place at the right time.
IaGary
02-09-2006 20:02:21
 Re: making a plow in reply to old, 02-09-2006 19:44:04
I agree with Old around here those plows usually don't bring many dollars.
Where are you located? I could keep my eyes if it not to far to transport.
mjbrown
02-10-2006 03:30:21
 Re: making a plow in reply to IaGary, 02-09-2006 20:02:21
I've noticed that small plows bring as much as a five bottom. Buy a bigger one and cut it down. Plows are going cheap because of the fuel they need. Round Up ready crops are making them obsolete.
KRUSS
02-11-2006 10:55:46
 Re: making a plow in reply to mjbrown, 02-10-2006 03:30:21
Plows of any kind are lawn ornaments, should be able to find one for scrap value. Why build one???
