disc harrow blades
JackSt
02-06-2006 18:09:28
I am replacing the disc blades on my JD BW harrow. When using notched blades, should the notches be in the same position on the gang bolt, or should they be staggered. Thanks for any help, only want to do this once.
JackSt
02-08-2006 07:38:53
 Re: disc harrow blades in reply to JackSt, 02-06-2006 18:09:28
Thanks for your reply's. Now off to fight with the removal of the spools and bearings.
JMS/MN
02-07-2006 08:22:08
No need to line them up. They work much better on cornstalks than smooth blades.
Dick2
02-07-2006 03:29:19
Question: What are you discing under that you need notched blades for? I used to work for a disc manufacturer. Notched blades were designed to grab cotton stalks so they would be cut and not slip around the disc. Because they are notched, the blades are thicker to prevent breakage - but that makes them harder to drive into the ground. My advise to owners was: If you aren't going to be discing under a lot of slippery stalks, don't buy notched blades.
Dick2
02-07-2006 03:28:34
Don L C
02-06-2006 18:23:22
Wont make any differance..... I staggerd mine, looks better a work.....
