differences in the older New Holland balers?
rleroy
02-04-2006 18:01:46
Would anyone care to tackle this?
For instance what are the differences (the not-so-obvious differences) between a 68, Hayliner 68 and a Super Hayliner 68?
Also the same question on 66, 67, and 69 and all of their versions.
I have the Norm Swinford book on Ford/New Holland and wondered how accurate the table on page 206 is? I own a New Holland Hayliner 68 and it's not even listed on Swinford's page 206.
rleroy
02-05-2006 11:58:46
 Re: differences in the older New Holland balers? in reply to rleroy, 02-04-2006 18:01:46
Hugh and mn Chuck,
Thanks, good info. I"m going to place this with my Swinford book.
Hugh MacKay
02-05-2006 05:24:47
leroy: I think Chuck basically has it. It was so long ago for me, I just don't remember evey little detail. I do know the rollers on the plunger was the single biggest improvment. Probably cut the HP requirments more than any other feature. I know NH didn't put the rollers on all models as they became Supers. I'm thinking 66 for sure and maybe 67 as well didn't get rollers.
mn.Chuckc
02-04-2006 18:19:54
A 68 and Hayliner are the same. A S-68 has
plunger bearings instead of blocks, has a
tine bar with bearing ends instead of bushings,
and I believe a rope pickup lift attach, A
diff part no on the crank arm for plunger.
The 66 is older,a narrower pickup,auger feed
instead of tine bar and wooden plunger blocks.
A 67 is a 1 yr newer but cheaper version of the
68 having a short 2 knuckle PTO shaft. The 69
(S-69)is more deluxe and mostly similar to a S-68
Chuck.
