Clover when to plant
Farmer76
02-03-2006 09:23:58
I am in NW PA. I would like to put in about 5 acres of clover this year. When is the best time to plant. As always any help is appreciated.
Punchie
02-04-2006 21:22:44
 Re: Clover when to plant in reply to Farmer76, 02-03-2006 09:23:58
HI 76
Beaver, PA Here . Drill in with your oats or at the same time you would plant your oats. Broadcaster if you can find one, frost seeding around mid- to late march. When ground is honeycomded from a freeze. Types up to you and what you are after, Mammoth for plow down and for one time harvest. Lindino (white) in sour ground. I don't use any others, Sell most of my hay to horse poeple.
Teddy
Jimmy King
02-04-2006 19:34:17
I am in Southwest MO. and I used to drill Red Clover in Fescue Sod in late Feb or March. I got a good stand most of the time.
Leland
02-04-2006 17:41:31
Just scattered about 30 acres today with atv in wheat and I live in ILL so asap .
Leland
02-04-2006 17:42:09
Leland
02-04-2006 17:42:14
barnrat
02-03-2006 10:41:28
Living in south western NY I seed my clover with a Massey 33 grain drill in mid April which is about as early as you can get on these muck clay fields. If we have frost It's usually gone by early April. Soil moisture dictates my timing. You can broadcast seed it in March if the snow is off the ground.
old
02-03-2006 10:17:31
We have always done it on the snow, with a broadcast seeder. The snow when it melts just pulls it in to the ground. So far it has always worked well, other then the last few years. We haven't had any snow in 2 or 3 years so it hasn't worked LOL.
Maark
02-03-2006 09:50:04
We always sowed clover when the oats were sowed in the spring. Usually after the frost is out of the ground. In Iowa, usually the end of March or 1st part of April.
