oliver plow
Scott KY
02-02-2006 19:19:53
I have a moldboard cracked on a plowmaster oliver plow. 14 inch bottoms. Does anyone know a source for a new one? Has anybody had any luck welding one and grinding it down?
old
02-02-2006 21:06:20
 Re: oliver plow in reply to Scott KY, 02-02-2006 19:19:53
I have a plow that has been welded up and it has been that way for years and is still holding. You could also try value-----bilt they havea lot of parts for the older plows.
Scott KY
02-03-2006 08:48:55
 Re: oliver plow in reply to old, 02-02-2006 21:06:20
Value only shows 16 and 18 inch bottoms. I'll try welding it up. Thanks.
old
02-03-2006 08:52:14
 Re: oliver plow in reply to Scott KY, 02-03-2006 08:48:55
If you weld it up use something like NI rod when you do. Most other rods will not hold up. The one I have we used the NI rod and it has been good since.
Scott KY
02-03-2006 08:23:36
