Oliver plow
Bill Tankersley
02-01-2006 05:26:24
Can anyone tell me where I can purchase a shear for an old oliver plow. The plow # is F1143 There is also a # on the shear 4677. I also found these # on the plow R141-A14. The shear has two mounting holes.
nwb
02-02-2006 07:02:19
 Re: Oliver plow in reply to Bill Tankersley, 02-01-2006 05:26:24
I think, and I say that with hesitation, that two hole shears are on 12 inch plows. Your numbers indicate 14" bottoms. Do the shears have two holes or the frog? In either case Scott is correct, TSC should have them. If the holes line up and the front end of the shear is in the right position. simply use the holes that line up. If it is a twelve inch plow you will need to cut the back side of the shear to length. Keep your receipt and if they will not fit you can take them back.
Scott KY
02-01-2006 05:53:02
I have 2 oliver plowmaster plows. I have gotten my shears from TSC. They have four holes. Mine just use three but they work fine. Are you sure your has only two holes?
