Dearborn Plow
Bill D (Va)
01-30-2006 06:47:34
While plowing some new ground I snapped the coulter/jointer arm. Anyone had any success at welding these arms or does anyone know where I might find another? Thanks.
Bill D.
Scott PA
01-30-2006 17:17:06
 Re: Dearborn Plow in reply to Bill D (Va), 01-30-2006 06:47:34
If you can't weld it click on "send email" to contact me. Does your coulter use a sway chain or does it have a stop built into the coulter?
Bill D (va)
01-30-2006 19:32:20
 Re: Dearborn Plow in reply to Scott PA, 01-30-2006 17:17:06
Thanks Scott. Mines an economy plow and has the built in stops. I plan on taking the arm to a welder this week, we"ll see what he can do!
Thanks.
Bill
Leroy
01-30-2006 15:25:18
Been using welded ones for years, common for that
Ultradog MN
01-30-2006 08:46:41
Bill, It would be possible for a good welder to weld the arm back together. But what I learned by looking at lot of old iron and junk is that most coulters are pretty much the same.
A chap near me has a bunch of junk Farmall Cub plows and parts and and while I didn't actually measure the shaft size or length on the coulters they looked identical to the ones on my Dearborn.
Probably other brands are similar too.
Good luck
Jerry
