New Holland Knotter again.
Kelly C
01-27-2006 12:02:40
I need a quick way for the rubes to tell if they have a standard knotter or a heavy duty knotter?
In my knotter service manual it shows standard knotters with just a grease zerk at the top where its mounted to the knotter shaft. On the heavy duty I see 2 cap screws there.
Is this a good identifier?
RickB
01-27-2006 12:47:05
 Re: New Holland Knotter again. in reply to Kelly C, 01-27-2006 12:02:40
Heavy duty knotter frames sit on a larger shaft (1-1/8"?). They also have a parting line and cap bolts similar to an engine's connecting rod so the HD frame can be swapped out without unloading the knotter stack from one end. HD knotter stack endplay is set with tapered collars, not shims.
