Sq Baler HP Requirements
Mike in Houston
01-26-2006 10:20:46
Anyone know New Holland's hp recommendation for:
276 sq baler
315 sq baler
326 sq baler
Local dealer has one of each and I'm trying to see about hp requirements before I stop by there to take a look at them.
Thanks for any help.
mee
dave from MN
01-29-2006 09:17:55
 Re: Sq Baler HP Requirements in reply to Mike in Houston, 01-26-2006 10:20:46
Baled this summer with a NH super 66 and a 46 "H". Worked fine as long as I didnt have to clutch. Of course the 66 makes a smaller bale. we baled days on end in the 80's with a IH baler with the roller thrower and a 300 with a working TA. If we baled as soon as the hay straw was dry and went till almost dark before the dew we put up a load every 15-20 minutes. Of course back then we were doing what had to be done to avoid facing the buyout as a last resort and we were young and strong and full of p*ss and viniger. I am waiting to see if I like the 544 hydro with a bigger baler this summer.
JK-NY
01-27-2006 16:20:15
I use a JD 5105 MFWD to run a JD 336 baler with thrower, and before I got the 336 I have run an IH 47/thrower and 16" kicker wagon behind both. The 5105 has enough power and is easy to shift on the go. Not sure if youre on hilly ground or pulling a wagon behind, the light weight of the tractor may limit you more than power requirements. Power requirements also depend on how heavy your hay crop is. With a 5105, you will notice the weight of the baler if you get a heavier one like the NH 315.
paul
01-27-2006 17:36:31
 Re: Sq Baler HP Requirements in reply to JK-NY, 01-27-2006 16:20:15
So then, what is the HP of a 5105 jd????
--->Paul
JK-NY
01-28-2006 15:10:06
 Re: Sq Baler HP Requirements in reply to paul, 01-27-2006 17:36:31
JD 5105 is 45 pto hp . I mentioned 5105 because it is the same tractor that is mentioned below by the fellow asking this baler question.FWIW I have run the 336 JD and 47 IH balers with a 4000 Ford and run the 47IH with a 770 Oliver , all 3 are 45-50 HP.
Mike in Houston
01-28-2006 04:57:54
45 pto horses. I'm planning on using the 5105 with the sq baler and the bigger tractor with a round baler this year. Bigger tractor and round baler will be doing alot of off farm work so wanted to make sure the 5105 would handle the sq balers I've been looking at for use at home. I'm having 40 acres sprigged with Jiggs (hybrid bermuda grass) this spring and hoping to get a couple of cuttings from it this year. At least one. Trying to win over some horsey people in my area.
Thanks for all the help everyone,
mee
Mike in Houston
01-28-2006 05:02:03
 Re: Sq Baler HP Requirements in reply to Mike in Houston, 01-28-2006 04:57:54
Oh, forgot to mention, flat ground, no wagon. Just pulling the baler and dropping the bales on the ground. Gonna pick them up the old fashioned way for a while until I get something rigged up for my front end loader to pick them up. Got an idea I'm going to play with for picking up squares. Kind of an accumulator/grapple combination. May work, may not but I'm going to try it. I'm sort of hard headed that way.
mee
JK-NY
01-27-2006 16:18:53
hay
01-27-2006 05:34:35
my 1973 Ford 4000 was used to run both a square baler and round baler at different times of it's life before i bought it. hp is 52 on the pto. your deere should be able to handle the balers you mentioned.
tim[in]
01-26-2006 15:46:51
i pulled a 14T behind a wd a/c with a wagon on hills. worked just fine. then a d 17. the thinf that helps most is a hi/lo or more speeds.
Mike in Houston
01-26-2006 12:41:17
Thanks for the replies guys. I'm running a Deere 5105 @ 45 pto hp. Tractor weight is 4000+ pounds (tires weighted). I've just seen where the newer New Hollands ask for 60 - 70 hp and didn't want to get something I can't handle. Thanks again guys.
I've got another question I'll post in another message.
mee
old
01-26-2006 12:29:50
35HP or bigger works well on most square balers. Live PTO is a big plus when useing one also. I usto us an Oliver 77 to pull a JD-14T and it played with that baler but my Ford 841 didn't do as well with it. The ford is rated as a 45HP tractor and the Oliver is 38HP, the live PTO on the Oliver made a real differance on the baler.
Hugh MacKay
01-26-2006 11:59:54
Mike: I don't think the hp requirments for those 3 balers will vary greatly. I had a S-69 which would also be in the same class only an older model. My baler had a thrower and I pulled 20' wagons behind always. My land was reasonably flat and over the years I pulled the baler with 3 different tractors. Started out with Farmall 300 then 560D and later 656D. The 300 still holds the record on my farm for the most bales in a given day, mainly because I had more good help to stow the bales away. I might add I also had a few bad hills, and the 300 did it before the other tractors were around. Bear in mind the 300 always had chloride and wheel weights, probably weighed as much as the 560 or 656. They had neither chloride nor wheel weights, just 16.9x38 tires.
Personally I still prefer that old 300 with narrow front for baling, problem was the 300 drank 3 Imp. gallons of gas per hour compared to 560D and 656D at about 1 Imp. gallon per hour. I do remember before having the 656, quite often we were baling and using 9' haybine at the same time. 560 always went on the haybine and 300 on the baler. The horsepower demands of the NH 460 haybine were greater than the baler, thrower and wagon.
I have baled and pulled the wagon on a few ocasions with the Farmall 130, when the other tractors were doing haylage. It wasn't fast, but it was only a small amount that got too dry for haylage. Since I had hired help doing haylage and I milked the cows morning and night and did this in between rather than shut the haylage operation down and have more hay too dry for haylage.
Square baling has never been about big horsepower but more about big manpower to handle the bales. I have baled 4,500 on each of 2 consecutive days with the 300. It took on average a dozen men to stow the bales in that old dairy barn.
RickB
01-27-2006 12:51:06
 for Hugh in reply to Hugh MacKay, 01-26-2006 11:59:54
Your assumption that a 69 is anywhere near the same class as a 326 negates any credibility you have on this topic.
Hugh MacKay
01-29-2006 16:19:10
 Re: for Hugh in reply to RickB, 01-27-2006 12:51:06
Rick: While I've never owned or used a NH 326, I have seen a few of them and also seen one of them work. Nothing spectacular, I expect had the operator sharpened his knife and made some adjustments he could have kept up with my 300 and S-69.
Can't even use my name
01-26-2006 16:44:28
 Re: Sq Baler HP Requirements in reply to Hugh MacKay, 01-26-2006 11:59:54
Are you telling me you baled 4500 bales each day? That sounds a bit far fetched. We have a NH 570 baler and use a 110 horse Case 1070 and I don't think we could bale 4500 in a day. Even in a 10 hour window which would be rare around here that is 450 an hour. That would really be pushing the max for any small square baler much less one smaller that a 570.
Hugh MacKay again
01-26-2006 17:57:27
 Re: Sq Baler HP Requirements in reply to Can't even use my name, 01-26-2006 16:44:28
Two things you may be doing differently, 40"+ bales weighing 60 to 70 lbs., for a bale wagon. With a thrower its a 30" to 36" bale weighing max 50 lbs. Two factors at work here thrower will not handle more than 50 lbs. and work well. Most of the bales would be down between baler and wagon. Secondly most of those guys stacking hay in the old conventional dairy barn were high school and college teenagers and they wont pile big bales all day.
Hugh MacKay
01-26-2006 17:39:02
You've got to remember with 45" annual rain fall and most cuts harvesting 200+ bales per acre. Many, many times I've baled 4,500 bales per day, but only once did I do it on two consecutive days. Did you read my last paragraph. Big horsepower has never been a factor small square bale haymaking.
If your running that kind of hp making square bales, where do you serve the hay, at the Walldorf?
WyoDave
01-26-2006 18:08:50
 Re: Sq Baler HP Requirements in reply to Hugh MacKay, 01-26-2006 17:39:02
Hugh, we put up a lot of hay, small square bales (125,000 bales last year), and run two 90 hp tractors and one 60 hp tractor. In 2-2.5 ton hay in 16ft windrows dropping 70lb bales on the ground with JD 348 balers the 60 hp tractor can"t run the same speed as the 90 hp tractors. These new balers have the capacity to really make hay, but you"ll have to have more horsepower then 35. You can still run the baler with 35hp, but you"ll never use its total capacity.
David
Hugh MacKay
01-26-2006 18:44:54
 Re: Sq Baler HP Requirements in reply to WyoDave, 01-26-2006 18:08:50
Dave: I suspect you didn't see my second post as you wrote this. Make note of what I said about bale throwers. It has been 30 year this summer since I square baled any hay. The only reason my 560 and 656 never baled more hay in a day than the 300 was labour. That is precisely why in 1975, feeding all my hay on farm, I went to a round baler, labour couldn't be found at any price.
I suspect some of these new balers can take more hp to work at capacity, however the 276 and others he was talking about are basically same baler as my old S-69 was.
01-28-2006 06:32:24
 Re: Sq Baler HP Requirements in reply to Hugh MacKay, 01-26-2006 18:44:54
If it has been 30 years since you handled hay squares don't you think the throwers have come a long way? Again, we have a 570 baler with a model 72 thrower which is run by hyd. orbital motors that are adjustable. To heck it can't throw a 75# bale (we keep ours about 55#). It can and will and throw it to the back of a 20' wagon already 3 layers high. That is how we stack ours. Back to front 3 layers then at the back again for another 3 or 4 layers. Now I say it again, even if we just let them go on the ground I think it would be pushing it to get 4500 baled in a day with one baler unless you have weather that permits baling 16 hrs a day.
Hugh MacKay
01-29-2006 16:11:28
 Re: Sq Baler HP Requirements in reply to Can't even use my name, 01-28-2006 06:32:24
I was not talking about todays throwers, I only commented on throwers of 30-40 years ago. Secondly I guess you best work a bit harder. If I dig around and if the old guys haven't died, I think I could find you 20 or 30 guys that have each baled 4500 bales per day on many ocasions and with as many different tractors. I doubt if any of them had 50 hp.
IaGary
01-29-2006 18:43:55
 Re: Sq Baler HP Requirements in reply to Hugh MacKay, 01-29-2006 16:11:28
Hugh I beleive it can be done.
We baled 2900 in 7 hours one day in about '73 with one 273 baler and put in the barn. 6 guys in the barn and three rotating in the field on the rack.
Hugh MacKay
01-30-2006 01:54:05
 Re: Sq Baler HP Requirements in reply to IaGary, 01-29-2006 18:43:55
Gary: Thank you, after my statment, I realized I may have trouble contacting some of those old guys that did in fact bale 4,500 bales per day. Two factors, I've moved 1,300 miles since then and secondly most of them are dead.
What some of these guys are not stopping to think of, is my bales on average were 45 lbs. For the guy doing 60 lbs bales, he need only bale 3,375 bales to bale the same amount of hay as I did. On the days I've baled 4,500 bales I would have had close a dozen men on the payroll. Hay making small square bales and stowing them away in one of those old conventional dairy barns had more to do with manpower than tractor horsepower.
That labor situation and the shortage of it, was precisely why I bought the 560D, later the 656 and still later 1066 and went into haylage. Good labor has never been easy to find on the farm, because of the short season. I will also say on days we baled those 4,500 bales, my dad and most of my 4 brothers were on hand, One of my brothers baled, one pulled wagons with an old Cockshutt 540. Dad cruised around with pickup keeping everything moving, pulling a few loads to barn with pickup if needed. The rest of us worked at and supervised packing of bales as we used a barn dryer, and care had to be taken not to have free air escaping.
I started haylage in the mid 60s. By 1975 my brothers were all gone off to their lifetime ocupations, dad was not as active as he had been, my S-69 was getting worn badly, thus I went to round bales to bale up what couldn't be stored as haylage.
Baling hay is not rocket science, you keep the machine in good order. Two things I see most frequently wrong with balers are plunger adjustment and dull knife. I can pick that one out 1,000 feet away by the shape of bales. It's not enough to have that knife sharp, it must be positioned so it shears. I found over the years, the limiting factor with an S-69 was the amount of hay that would feed through pickup, even with 35 horsepower.
WyoDave
01-26-2006 18:57:40
I know what you mean. But like all things related to farming it just takes more horsepower now than it used to. I would agree with you though, that by todays standards even the new higher capacity small balers still don't use much horsepower. David
caseyc
01-26-2006 10:43:05
well i'm not sure how they rank in size compared to a 336JD but they have to be close. i can pull my 336JD with an allis wd(about 35-40hp) with a rack on flat ground. it works but not my favorite. the 706 farmall is much better(about 75hp). it will work in a heavy windrow but not straining in anyway.
Theman's statement about 35HP on a stationary engine is about right to run the baler, not including pulling the weight of the baler, tractor and possible wagon behind up and down hills. a good strong M(about 45hp) or equal should do the job no problem, just becareful if you have hills and the wagon behind the baler starts getting full, that's where more HP/weight comes in handy.
casey in SD
Theman
01-26-2006 10:28:03
We use a 315 Hayliner that is PTO driven, but the manual states the output horsepower of the power unit at 36.
