JD 66 H 5 bottom plow
pdl
01-25-2006 14:42:35
My furrow axle is all worn and grooved on the inboard end from the wheel wobbling. The bearing sleave is also worn and out of round. Any idea on how best to rebuild the axle to original specs? You can't really put this thing on a lathe at 5 feet long and 2 90 degree bends in it.
Bob Collins
01-25-2006 18:00:59
 Re: JD 66 H 5 bottom plow in reply to pdl, 01-25-2006 14:42:35
The idea of the sleeve bearing is to protect the axle from wear. Wear happens between the sleeve and wheel box (bearing). I would weld up the wear on the axle and grind it smooth, the sleeve does not turn against the axle anyway. Then get a better (new?) sleeve and wheel box if needed and keep it greased. Tuppence from me $0.02.
jdp
01-25-2006 16:30:41
Cut it off at the bend and weld a new spindle and hub on be about as easy as anything
