veggie planter
Anderson farms
01-25-2006 04:06:01
I am looking for a planter to plant sweet corn, green beans, pumpkins, watermelons etc. What do you guys reccomend? I've been told to get a JD 33 or a JD 71. what do they look like? Does any one have any pics? I have a 2 row JD 6-7 planter would that work for the corn and beans? Thanks for any help. Sorry for the long post
John Atlanta
01-27-2006 04:34:56
 Re: veggie planter in reply to Anderson farms, 01-25-2006 04:06:01
We have a Monosem planter (a French machine) which has been in use for many years. It works on a vaccum principle and will accurately plant large seeds of any size or shape. It will even plant small seeds such as beets by changing the seed pickup discs.
Ks-farmer
01-26-2006 09:17:26
I have planted okra, sweet corn and a few others with my Dempster lister planter. We have even planted pumpkins. We ran a tube down to the seed drop tube and dropped the seeds in outselves. It just go slow. With the Dempster plates you can make them to the size and spacing you want by drilling them out with blank plates they also had predrilled.
riverbend
01-26-2006 20:03:57
 Re: veggie planter in reply to Ks-farmer, 01-26-2006 09:17:26
Other people I know drop the pumpkin seeds by hand. It works fine. I think that pumpkins could be planted with plates if you could figure out a way to get the seeds to lay flat in the cells without breaking them.
Brendon
01-25-2006 15:51:32
According to Deere literature, the 33 can only handle seeds up to 3/16" diameter so that would rule it out for what you are wanting to plant. On the other hand, the 71 can plant just about anything provided you have the proper plates, fillers, and hopper bottoms.
riverbend
01-25-2006 06:39:41
A JD 71 will work for corn, beans, but it will be tricky to plant large seeds like a pumpkin. The internal seed cut-off will probably do just that. The JD 33 planters are much less common. To see what a new 71 looks like go to Link .
