Oliver Combine Engines
Sandknob
01-22-2006 08:37:58
Which model of Oliver combines used Chrysler 318 engines? Just curious as I know where three old Oliver combines are and I would like to find one with the 318 motor as I know where a lot of parts for 318's are. Are these pretty much the same as truck 318's? What did the intake setup look like? Pictures? Asking because I was wondering if a later model Magnum motor would work in place of the industrial motor as the Magnums are more fuel efficient and can make more power.
Thanks
Adam Davis
Josh H
01-23-2006 17:49:16
 Re: Oliver Combine Engines in reply to Sandknob, 01-22-2006 08:37:58
I also have a green 7300 with 318. It has a two barrel carb on it, and I believe it is similar to the truck motor, but it has a gear driven governer on it. (Some may have been belt driven) The fuel injection on the magnum may give some trouble. Josh H
Sandknob
01-23-2006 19:13:09
 Re: Oliver Combine Engines in reply to Josh H, 01-23-2006 17:49:16
Thanks for the reply. Mopar now sells a carburated intake for the magnum motors now, as does Edelbrock and Professional Products.
Thanks again
Adam Davis
ChrisLSD
01-22-2006 16:34:42
our green 7300 has one - still runs - as far as i know - the combine drive broke so we pulled itin the trees
