New Holland round baler
Play farmer
01-21-2006 19:39:45
My buddy browht home the baler I ask you guys about a few weeks ago. It looks realy great for an older machine. We cant find a model number. It is the type with chains instead of belts. No owners manual and we cant figure out the twine system. It has a crank powered arm that guides the twine. But I cant see any mechanism to cut it and keep from using the entire roll of twine. It has natural twine now, can these also use the poly stuff? Any help would be greatly appreciated since neither of us have ever used a round baler.
thanks
DJM75
01-22-2006 07:49:41
 Re: New Holland round baler in reply to Play farmer, 01-21-2006 19:39:45
I have an 850 if I can get a pic of it soon I will send it too you and like old said the cutters aredown in there mounted on the left side if you were sitting on thractor with it behind you. The toughest part is getting a wire or something to pull the twine thru the long tube up front mounted on the craank or what ever mine has an electric motor. good luck
Allan in NE
01-22-2006 08:43:43
 Re: New Holland round baler in reply to DJM75, 01-22-2006 07:49:41
DJ,
Does your 850 with electric tie look like this one? I see this one has the oilers too.
Allan
third party image
DJM75
01-22-2006 13:48:35
 Re: New Holland round baler in reply to Allan in NE, 01-22-2006 08:43:43
yup that looks like it.
Allan in NE
01-22-2006 03:12:36
Mornin' Farmer,
Lots of those old devils had the hand crank option back then. Probably an 850 or 851.
Best way to tell 'em apart is the compression spring or springs and how they are built.
This is a hand crank 851, which was very popular back in the day.
Does it have one compression spring standing up at an angle and inside a tin sheild? Assuming it has the floor chains?
Those were some tough ol' buggers!
Allan
third party image
old
01-21-2006 20:54:17
Could be a number of differant ones. If I where to guess I'd say an 850 but with the info you gave it could be a number of differant one. With the twine rod in the home position which should be on the left as your sitting on the tractor seat there should be a knife section from what looks like a sickle mower. That is what cuts the twine. A picture would help a lot. You could also send me an e-mail and I'll send you a picture of an 850 from the front cover of the manual
old
01-21-2006 20:53:27
