Need info about sprigging
Ron in AR
01-19-2006 15:51:23
I just found out that our local conservation department is getting a couple of spriggers and will be renting them this year. I have a small bottom field (about 20 acres) that I would like to sprig in one of the hybrid bermudas, but I don't know the first thing about sprigging. Can anyone out there give me some basic info/pointers? Any help would be appreciated.
Txsprigger
01-20-2006 09:43:23
 Re: Need info about sprigging in reply to Ron in AR, 01-19-2006 15:51:23
Ron, what Willy said is correct. The key is planting the sprigs in a moist seedbed, and then packing it down so it does not lose moisture. Renting the sprigger is just part of the job, finding someone to dig you fresh sprigs and getting them to the field is another thing. The conservation district should have information on the types of bermudagrass that is adapted to your area. Here in Central Texas, the most common types are coastal, Tifton 85, and Jiggs. I have heard of Ozarka (I believe) up north into OK and Missouri, that may be better suited for you.
Ron in AR
01-22-2006 06:27:02
 Re: Need info about sprigging in reply to Txsprigger, 01-20-2006 09:43:23
Thanks for all the info gang. Appreciate your input.
HaySam
01-20-2006 06:55:07
Hay Ron you can get in big trouble
asking about sprigging on this board.
I know for sure.
HaySam
Willy P
01-19-2006 19:08:31
Sprigging is digging the roots of grass and then planting them in a Good MOIST seedbed,planting can be done with a manure spreader and scattering them on the ground and litely disking them in or using a planter and planting them in rows 2 or 3 feet apart and when it comes up it will cover the middles. If you have bottom land Jiggs bermuda grass would be your best choice but I am not sure how far north it can handle the cold winters. If you want send me your adress and I will be glad to help you because this is what I do in the spring time. Thank You
