Homemade chipper shredder
Doug S in Ne
01-16-2006 12:53:36
hi all. im looking at making a wood chipper shredder so when i clean up brush i can get ride of the left overs. ive heard of people making them outta old forage harvesters and taking out every other knife. do these work well? does any have any ideas? anyone every made one? the biggest diameter of wood would probably be 2.5 inches or less. let me know of any advice. thanks in advance.
buickanddeere
01-18-2006 19:15:23
 Re: Homemade chipper shredder in reply to Doug S in Ne, 01-16-2006 12:53:36
The feed rolls spin about 10 times too fast for one reason.
RickL
01-18-2006 06:17:47
Its your life but they are not designed for wood. Thats how lot of people get hurt,seen those knive fly out even whiloe chopping silage no way would I want to be standing around it sticking sticks int it wondering what s goint to happen,rent you a chipper or just burn it
RickL
01-18-2006 06:17:34
RickL
01-18-2006 06:17:28
Ben in KS
01-17-2006 05:14:40
Please listen to the other posts and let this idea go. A neighbor did this a few years ago, he was grinding trees and heard a funny noise, opened the machine and one of the forage knives flew out and hit him in the head. Whereupon he spent the rest of his life in a "managed care" situation. It is not worth it. Shop around and find a used chipper from a utility company or something. Ben
Myrl (PA)
01-17-2006 04:09:54
I have one I made from an old single row New Holland forage harvester. It worked very well behind my JD A. If you want you can email me for better description or pictures. Also worked for mulching a bank with old hay!
Blue3992
01-16-2006 19:49:05
Sounds like a lot of work. Why not just burn the stuff?
Butcher
01-16-2006 19:10:46
Dont know about making one out of a piece of farm equipment but, it would be the same principal as what is called a whisper chipper. The ones that are out there are called "chuck and duck" chippers. I've used them and u can get hurt or chipped into shreds real fast. Vermeer is a drum feed that has alot of safty featchures built in. Better safe than sorry.
supergrumpy
01-16-2006 14:39:55
I am clearing an old farm that went back to nature, whatever is too small for firewood got piled, but the brush piles got too big and I started renting/buying chippers
finally bit the bullet and got a real brush honest to goodness chipper, old Vermeer 1600 with 6cyl ford on it
when some of the larger stuff goes thru that 300cu is really working, the disc is very heavy and the chipping chamber is too, Vermeer did that for a good reason
Vermeer northeast has good pictures of their used equipment, please go with a machine designed for the job
buickanddeere
01-16-2006 14:09:54
It works until the person feeding a jammed branch gets sucked into the forage harvester. Same phenomenon as farmers loosing hands in combine corn headers.
thejdman01
01-16-2006 13:09:55
What are you planning to put it on? The size tractor, 540 or 1000pto and catorgory hitch will help us determine what would work well for you. I have seen a few home made ones but took quite some ponies to turn if you have the ponies would fill you in.
JD9295
01-16-2006 13:08:40
Doug, Im no forager man by any means, but that sounds like a major come apart waiting to happen.
If someone else has done it I would stick with that, let them have it.
Watch sales and used eguip. papers, pick one up from a tree company. The money u spend will be well worth it if that forager ever came apart while you were feeding it
Doug s in ne
01-16-2006 15:37:35
 Re: Homemade chipper shredder in reply to JD9295, 01-16-2006 13:08:40
i have a d21 ac and a 970 case. d21 is 1000 rpm and 970 is 540. there are slim and few tree companys around my neck of the woods. and ive seen a few vermeers sell but they are usually so wore out i would not trust any part of them.
