IH No. 37 14 Disc Blades
K-Mo
01-16-2006 07:19:13
Does anyone know an aftermarket source for 14" disc Blades. 1-1/8" square raised flat center?
K-Mo
paul
01-18-2006 02:27:26
 Re: IH No. 37 14 Disc Blades in reply to K-Mo, 01-16-2006 07:19:13
Shoup is a good after-market source for dsk parts, tho the rare-earth blades from Case-IH are probably better quality, folks speak highly of the OEM Case blades.
I agree with the rest, there is no use for a 14 inch blade, that is totally worn out, can't imagine you find any made new that small.
--->Paul
ejr-IA.
01-17-2006 09:46:21
This what I did is find a implement dealer or maybe a neighbor that rebladed a disk with new ones and use the old larger wore down ones the size you need like a worn 20" down to 18" and have them sharpend.
Leroy
01-17-2006 05:33:44
A 14" blade is a completly wore out unusable blade. 16" is too small to work correct on that disk, you need at least an 18" and that is what it came with, now if it is a 9" blade spacing version instead of the 7" spacing version then you need a 20" blade and you have the frame clearance to use them.
