No 5 mower hook up for JD M
Chuck730D SE
01-15-2006 13:48:37
I need the parts to hook a NoI can email you pictures and parts numbers if you need them.
Chuck730D SE
01-15-2006 13:50:07
 Re: No 5 mower hook up for JD M in reply to Chuck730D SE, 01-15-2006 13:48:37
CORRECTION, I need the parts to hook the No. 5 mower up to a JD M. I have the clamps, I need the parts that allow it to raise and lower.
Leroy
01-17-2006 05:52:40
 Re: No 5 mower hook up for JD M in reply to Chuck730D SE, 01-15-2006 13:50:07
Do you have the Quick tach or the flat drawbar mower? the quick tach should hook up without any extra parts and should raise the cutter bar with either a hand lift lever or a remote cylinder and if remote cylinder then you would need a hydrolic control that I don't know if John Deere made for your tractor for to use both the mounted hitch and cylinder at the same time
