JD 7' Drag Disk
HAS
01-14-2006 16:41:24
I have a 7' drag behind disk - JD. At least i think it's 7'. The front section is 84" and the back section is 92". One of the bearing housings is broken. Does anyone have any idea where I can get something like that?
I'd also like to trade this disk for a 5' or 6' disk that would fit on my trailer without taking it apart.
oldtractorboy
01-18-2006 07:43:29
 Re: JD 7' Drag Disk in reply to HAS, 01-14-2006 16:41:24
What you have there is a John Deere JB or JBA disk. I have one of these that we got new in 1953. If the disk has 28 blades, it is/was called a 7-footer. The parts catalog shows the JB made 1940-49 and the JBA from 1949 forward. My early 1960s John Deere catalog still shows the JBA disk.
TomTX
01-17-2006 14:17:29
Where is the picture. I can't find it. Want to help you. Tom
HAS
01-21-2006 08:34:41
 Re: JD 7' Drag Disk in reply to TomTX, 01-17-2006 14:17:29
Sorry it took so long for this reply - had to make a trip to Houston.
The pic is in the implement section of the photo ads on this web site.
TomTX
01-16-2006 01:29:52
Look closely for the JD ID tag. Does it have the model number??
HAS
01-16-2006 19:20:17
 Re: JD 7' Drag Disk in reply to TomTX, 01-16-2006 01:29:52
Where on the disk would I find the tag? I only found some green paint when I was working on it. There is a picture of it under the implements section of the photo ads.
Leroy
01-17-2006 06:01:15
 Re: JD 7' Drag Disk in reply to HAS, 01-16-2006 19:20:17
John Deere did not put tags on implements but it looks like the light weight Deere disk but I can't think of the model no. now and for size you measure the width of the back gangs and thw width might be like 7'6" or 7'3" or something like that in measurements, not just a foot rating
TomTX
01-17-2006 14:10:22
 Re: JD 7' Drag Disk in reply to Leroy, 01-17-2006 06:01:15
Leroy,
My JD offset disk was made back in early 1950s and it has an aluminum, rectagular tag, rivited to the frame, with Model Number and Serial Number.
I can't find the picture he is referencing to, so I guess I can't help without the name of the picture or something.
Leroy
01-17-2006 16:14:44
 Re: JD 7' Drag Disk in reply to TomTX, 01-17-2006 14:10:22
I found the picture he is refering to and his disc is a 30's-40's vintage and that model never had a tag, only in late 50's did tags start showing up and then in 60's when they got to be a regular item. I think the first letter in his model is a J, I know it is not in the KB series and it is a 4 gang light weight drag disc sold for the small model B JD tractors, if I would have the time to dig that hard I could find a complete model no for it and the measurement he gave for it would make it a 7 1/2' size
