7000 wide planter-how narrow?
John51
01-13-2006 09:18:05
Looked at a JD 7000 wide 4 row planter. It's set at 38 inch rows. How narrow can I make it?
Thanks
farmerboy
01-16-2006 06:00:39
 Re: 7000 wide planter-how narrow? in reply to John51, 01-13-2006 09:18:05
What I'm doing is buying a 7100. It's the 3 point version of the 7000. They bring the same price and have the same row units. To modify you only need to move brackets and cut off some of the transmission.
You need a fairly large tractor to run them. I'm gonna try a 4430 but have a 4640 if necessary. Also, you can't put fertilizer on them - at least I've never seen one with fertilizer...
Ray Hudson
01-13-2006 16:46:21
without cutting and rewelding wheel brackets it wont go to 30 in I did mine 5yr ago it worked great
fordfarmer
01-13-2006 11:13:17
I used to have a 7000 4 r.w.(6r.n. now). I think 36"is as narrow as they will go. It says in the owner's manual, if you have access to that.
Doug in IL
01-13-2006 16:59:20
 Re: 7000 wide planter-how narrow? in reply to fordfarmer, 01-13-2006 11:13:17
I just looked in my owners manaul. It says 36 inches.
John51
01-13-2006 12:31:37
Thanks. No, I'm just looking at it and wanted to know first.
