Round balers
used to be Jame
01-06-2006 16:39:02
How many bales does it take to remove all the paint from the walls of a new round baler?
Just trying to get an idea of usage on a used baler.
Thanks,
James
Andrew from KY
01-07-2006 13:24:06
 Re: Round balers in reply to used to be James, 01-06-2006 16:39:02
It also depends on the operator and if they are filling the bale chamber up when they are baling. If you make bales that are uniformly fed on all sides as well as the middle the side walls won't have enough hay rubbing against them to wear off the paint.
504 Baler Guy
01-07-2006 08:38:41
It really depends on the hay. I saw a baler this winter that had baled 2000 bales of coastal bermuda this year and had just started to wear the paint in spots. Tougher crops such as corn stalks and peanut hay will wear the paint much faster.
James
Nebraska Cowman
01-07-2006 03:40:12
Paint????? ???the tin on mine is wearing thin in spots.
