Best built box blade available?
fixitforfree
01-05-2006 18:50:05
Which manufacturer makes the best built 6" box blade? My wife"s grandfather has a JD 2040 tractor and is in need of one. He is pretty hard on equipment and needs one as good as you can buy. At his age, the money doesn"t really matter. Give me suggestions if you can and tell me specifically model numbers if you know them. He wants to buy one this Saturday so I need help quick. The best I"ve seen are Gannon"s but I can"t find a dealer locater on the web. Heck, there may be better out there anyway.
CharlieN
01-06-2006 20:10:18
 Re: Best built box blade available? in reply to fixitforfree, 01-05-2006 18:50:05
Best ever was danhuser.Now it's gannon.Take the models with hydraulic scarifiers,add power tilt and top link you got all you need.Started setting up grading trators in the late 70s and still doing it today.Good luck.
CharlieN
01-06-2006 20:09:34
Best ever was danhuser.Now it's gannon.Take the models with hydraulic scarifiers,add power tilt and top link you got6 all you need.Started setting up grading trators in the late 70s and still doing it today.Good luck.
msb
01-06-2006 18:55:19
I have a Servis.Don't know if they are still in business ,but it has to be the heaviest built one I have ever seen.Bought it almost 40 years ago.
jdp
01-05-2006 20:11:32
gannon is the best i have found i have a six foot might sell in illinois woods bought gannon a couple years ago check them out at www.woodsonline.com
jdp
01-05-2006 20:49:19
 Re: Best built box blade available? in reply to jdp, 01-05-2006 20:11:32
www.woodsonline.com click on gannon go to industrail scrapers hd-4272-hd has haudralic teeth ,i have a tounge and wheel set up for mine to make it a pull type is alot easier to level things out with it
fixitforfree
01-05-2006 18:51:10
I meant 6' box blade.
