Little Genius 3 bottom plow
Jeff Jackson
01-03-2006 10:22:37
I have a Little Genius 3 bottom trip plow on rubber I want to use this spring. What are the correct positions for the adjustments levers when opening a new furrow and for plowing once the furrow is opened? Thanks for any and all advice.
Hugh MacKay
01-03-2006 14:05:30
 Re: Little Genius 3 bottom plow in reply to Jeff Jackson, 01-03-2006 10:22:37
Jeff: When you strike out a field both lever must be set quite deep, ie. levers up. As soon as you've made that first pass your right lever can be set much more shallow as the right wheel will be in furrow. From there it is just a matter of achiving the depth you want and keeping plow cutting same depth on both sides.
