Disk help....
spray004
12-29-2005 18:39:04
We have a 12' PICO Poplarville Mfg Co. disk that is pretty old. Its model #180. One of the wheel bearings is gone. Besides pulling the other wheel bearing and trying to match them up at Napa, can anyone point me in the direction for parts? I searched on the 'net for the company but I'm pretty sure they are out of business.
John A.
12-30-2005 05:34:31
 Re: Disk help.... in reply to spray004, 12-29-2005 18:39:04
Spray004, Just "Buck-up" and get yourself in a mind set to pull the other spindle assembly.
First after checking to see that both hubs are the same. Wash up that hub, get all the grease out of it, the bearings too. Don't go to the Napa's of the world. Go to the Yellow Pages and look for a Bearing Supply House. "IE...here in Central Texas one of ours is Pervis Bearing." There will be someone in your area that supplies bearings to the public at large for uses other than automotive.
With the bearing/race #s they can get you going.
In the outside event you can't get the bearings to fix that assembly, most trailer supply houses or even Tractor Supply sell new weld in axles and you can fix your problem from that angle too. Hope this helps!
Later,
John A.
