PTO drive: 3 point vs tow behind implements
TD5Doug
12-26-2005 11:17:33
I'm tring to get my head around the dynamics of pto drives on tow behind implements. Do they absolutely need a steady bearing/2piece drive shaft or can you drive something like a T.B. brush cutter with a single shaft like a 3 point mount implement. I can see how this works on a 3 point as the major change in drive line angle is in the vertical plane with next to nothing in the horizontal plane, but on a tow behind the drive angles change in both planes?? I've seen T.B. implements driven both ways & got me wondering.
old
12-26-2005 11:45:18
 Re: PTO drive: 3 point vs tow behind implements in reply to TD5Doug, 12-26-2005 11:17:33
Either type work on either type of equipment but, I have found universal joints last long if there a bearing that holds the shaft on the pull type machines.
