Ford Plow
DKHall
12-22-2005 18:28:43
I am restoring a 2btm 14in ford plow. Mod# IO337. I plan on using this plow next spring in some very heavy clay soil that has not been turned sence the 1930`s (This stuff is harder than supermans kneecap). Can I use a grade 5 bolt for the sheer pins or do I need something softer. Thanks for the help DKHall
jimont
12-23-2005 05:58:34
 Re: Ford Plow in reply to DKHall, 12-22-2005 18:28:43
If you use anything softer than grade 5, better go to the field with a bag full. Been there , done that, learned the hard way to use grade 5 in clay.
jdp
12-22-2005 18:42:58
what are you planning on pulling this plow with? a regular shear bolt will probably hold it because it will be a steady pull. you need to think about having some one pull an aerway or other tool like that through the area first to loosen it up some for you
DKHall
12-26-2005 17:25:09
 Re: Ford Plow in reply to jdp, 12-22-2005 18:42:58
I will be pulling this plow with a MF 50 (around 35 HP). My dad has a 2290 case with a 5 shank ripper I may pull this over the ground before I start Plowing. I also need to know how tight the piviot bolt on the trip part of the plow needs to be. Thanks to everyone for the help.
Ken Crisman
12-22-2005 20:19:54
If you have a subsoiler , run it through the field in places to help break the clay some . Then go with the plows . I would use grade 3 bolts so not to break something else . Ken
