nh 315 baler
bob sprinkk
12-21-2005 17:08:02
need to know what minimun hp is needed to run properly thanks bobsprinkk
rwood
12-22-2005 17:33:41
 Re: nh 315 baler in reply to bob sprinkk, 12-21-2005 17:08:02
I run a NH 315 baler with a 70 kicker using a Ford 5000 (65 hp) with no trouble.
rwood
12-22-2005 17:32:41
bob sprinkk
12-22-2005 17:02:21
hey guys
thanks for info on nh 315 baler is there a
difference between engine hp and pto hp
learning as i go wet feet thanks bob sprinkk
BobMo
12-22-2005 19:11:41
 Re: nh 315 baler in reply to bob sprinkk, 12-22-2005 17:02:21
There is a difference between engine and pto hp. Engine hp will always be higher than pto hp. Usually this is lost through drive or the way hp is computed. PTO hp will give you a more accurate description of the actual available hp.
chief 83
12-21-2005 22:06:15
I ran my 315 for several years with a JD 870 (about 28hp). No doubt it was work for the tractor but I had 0 problems. I don't pull a wagon. I now use a larger tractor which is much better (MF 245.
Andrew from KY
12-21-2005 19:58:32
I worked for a guy in high school that had a 315. He ran his with either a 175 Allis or a 6080 Allis. They had plenty of power to run the baler, just needed a little more tractor since some of what we baled was on hillsides.
BobMo
12-21-2005 18:34:35
I have one and I think the original literature indicated 35 hp was sufficant however unless you have a heavy 35 hp tractor it won't be enough. Newer 35 hp tractors won't cut it.
If you pull a wagon you'll need 50 plus. Hills and heavy hay will also require added hp.
Good luck.....
