WAGNER loader cylinders
Richard from SE
12-19-2005 18:02:54
I have a 2n that I use around my place in SE AZ.
(Love that machine !!!)I have a Wagner loader for it that I put on it only when I need it. Not to often but what a life saver, even with the hassle of putting it on and taking it off.My problem is that the lift cylinders and the bucket cylinder leak really bad.Does anyone know if the seals are still available for these cylinders or will I have to replace them??? Also, the front mounted pump leaks some too. Are these rebuildable???
If anyone knows, where can I get the parts or where can I get replacement cylinders???
Thanks to all who reply and MERRY CHRISTMAS to you and your familys. (by the way, the temp. here is in the low 70s and it will be all week. Just left a job in Durange CO. I like it here better.)
Coldiron
12-20-2005 09:01:18
 Re: WAGNER loader cylinders in reply to Richard from SE AZ, 12-19-2005 18:02:54
Remove your wipes and seals and take em down to your local hydraulic shop. They will more than likely have what you need at a reasonable price. They usually have bulk hyd fluid too that is a lot cheaper if you have your own can.
Colorado Curt
12-20-2005 08:14:04
Baum Hydraulics should have the seals for you. Merry Christmas to you.
