Equipment storage
TomIN
12-13-2005 15:55:29
Because of theft/vandalism issues I have to store my Ford 600 tractor, Gravely two and four wheel tractors, and attachments inside an alarm protected garage at my weekend home. With eleven foot ceilings in the garage I have a lot of cubic feet for storage--but everything is one layer deep on the floor. The really heavy items (bush hog, box blade, etc are positioned where I can back up to them. Has anybody in a similar situation found an economical way (not buying a forklift truck) to conserve space or to put things on "dollies" so that it can be moved more easily?
barryinmn
12-17-2005 16:31:16
 Re: Equipment storage in reply to TomIN, 12-13-2005 15:55:29
I ringed the barn with used 42" pallet racking and wire mesh decking. Then bought dozens of used pallets from local pallet shop.
Did buy a $800 gas towmotor forklift with 12' reach.
Pile stuff on pallet put on shelf. done!!
Snowmobile 10' length spends the off season 8' high on top of pallet rack on a skid & couple of osb sheets.
Uprights are $20 cross beams are $10 mix and match heights & lengths. Holds 4-6000 lbs shelf. Park stuff under, make workbench. Make a place for everything & put it away..
Now only things on the floor of my barn have wheels on them.
Not what you wanted to hear but much safer: no climbing ladders no falling materials etc...
Galen
12-16-2005 18:49:47
A neighbor where I used to live used a boat winch to set his 5' brush hog on it's tail and chained it to the wall. Hung his boom pole, and other small implements against the wall on chains. He, also, had a "loft" built for small stuff.
MonT
12-19-2005 07:14:12
 Re: Equipment storage in reply to Galen, 12-16-2005 18:49:47
About anything would work...but doesn't sound verry safe!!!
MonT
12-19-2005 07:07:33
BobinKY
12-14-2005 06:10:51
I too have built a loft in my barn and it works well for storing things that you can lift that high. We have even lifted some stuff up in the bucket on the tractor. I wanted to mention to you that Harbor Freight has those dollies for cheap and they are not bad. I have two old classic cars sitting on them yearound when I am not driving them, and they have not sagged or bound a wheel yet. You need a good smooth and clean concrete floor to work properly. If your barn is anything like mine, that may be a problem.
cj3b_jeep
12-14-2005 05:29:04
How about a used shop crane? You could build a really sturdy platform, move stuff onto it with the shop crane.
Hugh MacKay
12-13-2005 17:18:31
Tom: I'm not sure this would suit your situation, however I use pallets to store my tractor implements on, items like 2 bottom plow, 5' disk, cultivator, etc. I have a pallet jack and this allows me to store these much closer together than placing with tractor. I store most implements along the wall, when I want one I just roll it out with jack. Used jacks can be bought very reasonable.
What I have above the implements are wide shelves I can use for items up to 100# that I can put there by hand. This shelf is only about 4' above floor. I have been thinking about a second shelf, above the first, rugged enough to withstand real heavy items. I would then use chain lift on a track down long wall of shop, over the proposed shelf. That last on is just in the think stage.
55 50
12-13-2005 16:58:30
I haven't tried this but how about those deals I see advertised where you jack up wheels of a vehicle and place a dolly under each wheel which allows you to move them any direction you desire and they can be right next to one another as long as they don't bump or scratch paint on other vehicles. Seems these dollys might work for you even on items that don't have wheels.
You probably already have figured out "upper" storage for the less heavy items. If not, I can add that I built 8 ft X 8 ft overhead lofts in two back corners of my shed. My shed has 12 ft clearance under the roof trusses and with the lofts 8 ft off the floor, it is still possible to stand up on most of the loft area. 8 ft clearance under the lofts allows tractors, pickups, cars etc., to move freely under them if needed. I supported the lofts from above to allow the free movement under them.
Michael Soldan
12-13-2005 18:05:50
 Re: Equipment storage in reply to 55 50, 12-13-2005 16:58:30
55-50, I like your idea, a friend of mine built a shelf 8' off of the floor, 4 feet wide half the width of his 40'x80' shed. He stores an incredible amount of stuff up there and can still park machinery underneath. I plan to do something like that in my shed this summer...Mike in Exeter Ontario
