Homemade implements
Scott Hansen
12-13-2005 13:03:50
Does anybody happen to know the dimensions of a 3 point attatchment right off? I would like to make a small subsoiler for my 3 point.
hay
12-15-2005 05:06:08
 Re: Homemade implements in reply to Scott Hansen, 12-13-2005 13:03:50
i just completed a subsoiler attachment for my one row cultivator. took it on it's maiden voyage earlier this week. i used the existing 3 point on the cultivator and bolted the subsoiler beam to it and welded brackets for subsoiler shanks. cuts great, but with a small tractor you really have to be careful not to overload it especially in heavy soil. i also made a complete spike harrow with homemade 3 pt, but don't have the exact specs right now.
ChrisLSD
12-13-2005 13:09:10
to the left of these messages near the bottom is the link that says 3 point specs.....
Scott Hansen
12-13-2005 13:16:01
 Re: Homemade implements in reply to ChrisLSD, 12-13-2005 13:09:10
OK, that worked as far as pins go, but I was thinking about the distance between pins, and the distance to the top link, and angles, if there are any to worry about. I did find a subsoiler for under $300, but I thought it would be a good project.
Scott Hansen
12-13-2005 13:22:40
 Re: Homemade implements in reply to Scott Hansen, 12-13-2005 13:16:01
There. Found the article.....all info is there.
Aaron SEIA
12-13-2005 13:09:01
Check the 3 pt specs link on the left side of the page. Thought about making one for myself, but the $130 one at the farm store is probably way cheaper than I could build for.
Aaron SEIA
Scott Hansen
12-13-2005 13:11:14
 Re: Homemade implements in reply to Aaron SEIA, 12-13-2005 13:09:01
I'll be. I never noticed that before. Thanks, guys!
JMS/MN
12-13-2005 13:54:51
 Re: Homemade implements in reply to Scott Hansen, 12-13-2005 13:11:14
For months I posted the asae.org website, which used to have all dimensions- then they went to providing that info if you were a $ member. I just checked the site here, on the left, and don't see more than pin diameters- nothing about vertical/horizontal dimensions. What am I missing? Where ndid you see it all?
Scott Hansen
12-13-2005 14:17:45
 Re: Homemade implements in reply to JMS/MN, 12-13-2005 13:54:51
First paragraph, there is a link to an article (HERE). Info is embedded in the article. Took me two reads to get it....
Galen
12-16-2005 19:01:37
 Re: Homemade implements in reply to Scott Hansen, 12-13-2005 14:17:45
I STILL don't see a dimension for the distance between the lift pins and the top link! I just measured one and built accordingly.
