Ford mounted corn picker question
Bill A
12-13-2005 10:49:43
I am attempting to hookup a ford cornpicker, not sure the model but it is the "blue" one, not the red. Everything is attached and it works, but there is one bracket that I know I have not hooked up correctly. It is the bar that will rotate with the header assembly. I'm sure it is designed to be held stationary and for the time being I have chained it in place but what is the correct attachment here? I can send pictures if it will help describe my problem.
Also, does anyone out there have manuals for this unit?
Scott PA
12-13-2005 17:30:07
 Re: Ford mounted corn picker question in reply to Bill A, 12-13-2005 10:49:43
If it is a 1 row you need to disconnect both vertical 3 point lift rods from the horizontal 3 point lift arms on the tractor and conect the right adjustable one to the snout lift bracket on the picker, the main frame of the picker is carried on the rear axle brackets not on the 3 point hitch of the tractor.
J.C. IN AZ.
12-13-2005 11:56:36
Just for correpondence I had a "Blue " ford picker on a D17 AC. was a very good picker. Can't help on your problem but I think you will be satisfied with the job it will do.
Jim.UT
12-13-2005 10:52:24
I see manuals for Ford corn pickers come up on ebay about once or twice a month.
Can't help you with the mounting question. Sorry.
