Bushhog 315
ldp
12-02-2005 15:48:00
I just bought a Bush hog model 315, the heavy duty 15 footer. Some of the gear boxes are leaking. I was wondering if you have to remove the gearboxes to replace the bottom shaft seals. Or can you get to them after removing the stump jumpers? Just wanted to know the easy way to replace the seals. Thanks!
jim1650
12-03-2005 02:53:50
 Re: Bushhog 315 in reply to ldp, 12-02-2005 15:48:00
well we have two of the 2610 bushogs same as u just one wing and we just pick up the hitch with a loader and hold it so we can get under it don't forget to block it we raise it about five or six foot after u get it block just pull the stump jumper which some times has to be heated or cut to remove it and then there a dust cover and then the seal .any other ? just ask
